iPhone 16 Pro Max iPhone 16 Pro iPhone 16 Plus iPhone 16 iPhone 15 Pro Max iPhone 15 Pro iPhone 15 Plus iPhone 15 iPhone 14 Pro Max iPhone 14 Pro iPhone 14 Plus iPhone 14Galaxy A
Galaxy A90 Galaxy A80 Galaxy A72 Galaxy A71 Galaxy A70 Galaxy A60 Galaxy A55 5G Galaxy A54 Galaxy A53 5G Galaxy A52s 5G Galaxy A52 Galaxy A51 5G Galaxy A51Galaxy A50s Galaxy A50 Galaxy A42 Galaxy A41 Galaxy A40s Galaxy A40 Galaxy A35 5G Galaxy A34 Galaxy A33 5G Galaxy A33 Galaxy A32 5G Galaxy A32 Galaxy A31Galaxy A30s Galaxy A30 Galaxy A25 5G Galaxy A24 4G Galaxy A23 5G Galaxy A23 Galaxy A22 5G Galaxy A22 Galaxy A21s Galaxy A21Galaxy A20s Galaxy A20e Galaxy A20 Galaxy A16 5G Galaxy A16 Galaxy A15 Galaxy A14 5G Galaxy A14 Galaxy A13 5G Galaxy A13 Galaxy A12 Galaxy A11Galaxy J8 Galaxy J7+ Galaxy J7 Pro Galaxy J7 Prime Galaxy J7 Max Galaxy J7 Core Galaxy J7 (2018) Galaxy J7 (2017) Galaxy J7 (2016) Galaxy J7 Galaxy J6+ Galaxy J6 (2018)Galaxy S24 FE Galaxy S24 Ultra Galaxy S24+ Galaxy S24 Galaxy S23 FE Galaxy S23 Ultra Galaxy S23+ Galaxy S23 Galaxy S22 Ultra Galaxy S22+ Galaxy S22Galaxy S21 FE Galaxy S21+ Galaxy S21 Ultra Galaxy S21 Galaxy S20 FE 5G Galaxy S20+ Galaxy S20 Ultra Galaxy S20 FE Galaxy S20Galaxy S10e Galaxy S10+ Galaxy S10 Lite Galaxy S10 5G Galaxy S10 Galaxy S9+ Galaxy S9 Galaxy S8+ Galaxy S8 Active Galaxy S8Galaxy Ace 1 Galaxy Ace 2 Galaxy Ace 3 Galaxy Ace 4 Galaxy Ace 4 Lite Galaxy Ace Duos Galaxy Ace Style Galaxy AlphaGalaxy C5 Galaxy C5 Pro Galaxy C5000 Galaxy C7 Galaxy C7 Prime Galaxy C7 Pro Galaxy C8 Galaxy C9 Galaxy C9 Pro Galaxy Core 2 Galaxy Core LTE Galaxy Core Prime Galaxy Core Prime VEGalaxy Gio S5660 Galaxy Grand 2 Galaxy Grand Max Galaxy Grand Neo Galaxy Grand Plus Galaxy Grand Prime Galaxy Grand Prime +Série 11 et plus
Xiaomi Mi 11 Pro Xiaomi Mi 11 Lite 5G Xiaomi Mi 11 Ultra Xiaomi Mi 11 Lite Xiaomi Mi 11i Xiaomi Mi 11 Xiaomi Mi 10T Pro Xiaomi Mi 10T Lite Xiaomi Mi 10T Xiaomi Mi 10 Pro Xiaomi Mi 10 Lite Xiaomi Mi 10Xiaomi Mi 9T Pro Xiaomi Mi 9T Xiaomi Mi 9 SE Xiaomi Mi 9 Lite Xiaomi Mi 9 Xiaomi Mi8 SE Xiaomi Mi 8 Pro Xiaomi Mi 8 Lite Xiaomi Mi 8 Xiaomi Mi 6Xiaomi Redmi 14C Xiaomi Redmi 13C 5G Xiaomi Redmi 13C Xiaomi Redmi 12C Xiaomi Redmi 12 4G/5G Xiaomi Redmi 10 (2022) Xiaomi Redmi 10C Xiaomi Redmi 10A Xiaomi Redmi 10Xiaomi Redmi 9AT Xiaomi Redmi 9T Xiaomi Redmi 9C Xiaomi Redmi 9A Xiaomi Redmi 9 Xiaomi Redmi 8A Xiaomi Redmi 8 Xiaomi Redmi 7A Xiaomi Redmi 7 Xiaomi Redmi 6A Xiaomi Redmi 6Xiaomi Redmi Note 13 Pro+ 5G Xiaomi Redmi Note 13 Pro 5G Xiaomi Redmi Note 13 Pro 4G Xiaomi Redmi Note 13 5G Xiaomi Redmi Note 13 4G Xiaomi Redmi Note 12S Xiaomi Redmi Note 12 Pro+ Xiaomi Redmi Note 12 Pro 5G Xiaomi Redmi Note 12 Pro 4G Xiaomi Redmi Note 12 5G Xiaomi Redmi Note 12 4G Xiaomi Redmi Note 11 Pro+ 5G Xiaomi Redmi Note 11 Pro 4G/5GSérie Mate
iPhone 14 Pro / 14 Pro Max
Ecran
Guide de réparation : Ecran iPhone 14 Pro / 14 Pro Max
Le remplacement de l'écran de l'iPhone 14 Pro est une procédure délicate qui nécessite une attention particulière, étant donné les caractéristiques avancées et la qualité de construction de cet appareil haut de gamme. Lancé le 16 septembre 2022, l'iPhone 14 Pro se distingue par son écran LTPO Super Retina XDR OLED de 6.1 pouces, offrant une résolution de 1179 x 2556 pixels et une luminosité pouvant atteindre 2000 nits. Cette technologie d'affichage, combinée à la prise en charge du HDR10 et du Dolby Vision, assure une expérience visuelle immersive, avec des couleurs vives et des noirs profonds.
L'écran de l'iPhone 14 Pro est également protégé par un verre Ceramic Shield, réputé pour sa résistance aux chutes et aux rayures. Cependant, malgré cette robustesse, l'écran peut être endommagé suite à un impact violent, une chute ou une pression excessive. Dans ces cas, un remplacement de l'écran devient nécessaire pour restaurer la fonctionnalité et l'esthétique de l'appareil.
Ce tutoriel vise à guider les utilisateurs à travers les étapes du remplacement de l'écran de l'iPhone 14 Pro, en mettant l'accent sur la précaution nécessaire pour manipuler les composants sensibles et maintenir l'intégrité de l'appareil. Il est crucial de suivre attentivement chaque étape et d'utiliser les outils appropriés pour assurer un remplacement réussi et sécurisé de l'écran.
Mais avant de changer l'écran de votre iPhone 14 Pro, nous vous recommandons d'effectuer une sauvegarde complète de vos données par précaution.
- Ecran noir
- Ecran cassé ou fissuré
- Présence de rayures
- Problèmes d'affichage
- Tactile défaillant
Kit outils Spécial - N°1 8.90€ Voir le produit visibilityComment remplacer ecran pour iPhone 14 Pro / 14 Pro Max - Guide images
Procédez à l'extinction de votre iPhone 14 Pro avant d'extraire le tiroir et sa carte SIM.
Sortez les deux vis pentalobe de leur emplacement.
Chauffez l'écran à l'aide d'un sèche-cheveux ou un décapeur thermique.
Soulevez l'écran avec la ventouse afin de pouvoir introduire le médiator en métal fin entre la vitre avant et le châssis.
Remplacez par la suite l'outil par la spatule verte. Faites circuler l'ustensile sur toute la longueur de l'écran pour le décoller.
Faites basculer le composant vers la gauche.
Retirez les 8 vis avec le tournevis triwing.
Récupérez la plaquette de protection avant de débrancher la nappe de la batterie. Attaquez-vous ensuite aux nappes de l'écran.
Ôtez les deux vis avec le tournevis cruciforme.
Mettez de coté la plaquette métallique qui protège les capteurs.
Chauffez la nappe.
Introduisez le levier sous la nappe pour la décoller délicatement du dos de l'écran. Soulevez les capteurs en vous aidant de la pincette.
Mettez de coté la nappe.
Pour remonter votre iPhone 14 Pro / 14 Pro Max suivez ce guide en sens inverse.
